  #139 (permalink)
Old 06-01-2011, 04:19 PM
madmaxx madmaxx is offline
I meant no opinion towards the current thread owner or anyone else. I have had similiar problems in the past and it seams the owner is always blamed never the builder, manufacturer or parts supplier, so if I blame myself for everything it does not hurt so bad This poor guy got so screwed it hurts.
Originally Posted by Jac Mac View Post
Im curious, were you having to add coolant, or to be more correct, was the radiator coolant level dropping each time you used the car.
There are marks/indentations on the oil pump rotors that indicate some circlips or similar parts have tried to pass thru the pump ( yes the wire type circlips can get thru the pickup mesh )
madmaxx's comments in post 137 above are a bit harsh, but I can understand his sentiments, to continue to use any vehicle when it has an obvious problem transfers a large part of the responsibility to you or whomever drives it. I think the term is 'caveat emptor' or ' let the buyer beware'.... probably applies particularly in cars like this..
