Old 06-02-2011, 06:29 AM
lemans24 lemans24 is offline
Cobra Make, Engine: kirkham stroker 48 webers
i turn my fuel pump off and run the gas out till the engine starts to stumble. that does help some. my take on it is the fuel in the bowls is boiling and the pressure from the boiling gas is forcing it out the top of the carbs. i put on phenolic adapters to try to isolate the bottom of the carbs from the manifold.
alot of people are having th same problem. must be the fuel. i'm going to run only non ethanol gas and maybe try some seafoam.
