Nick,
What if you were to manufacture a lower control arm for the Jag IRS. However also make a new bearing carrier with the mounting hole angled upward toward the front. This would make the bearing carrier pivot in and out through travel giving you toe/steer? I would also think the angled hole would have to be equal distance from the original position. The right angle would need to be found!
