  #21 (permalink)
Old 06-02-2011, 07:25 PM
DAVID GAGNARD's Avatar
A dyno is like any other tool, it can be used for it's intended purpose or mis-used.......
When I dynoed my 331 race motor, the dyno operator (also an engine builder,with a lot of expirence in small block Fords)told me it would probably do the best at 30 to 32 degrees total timing,we started at 30.....he also told me my jetting should be real close....after the break-in and cool down, we began making pulls, jetting was perfect, we adjusted the timing from 26 degrees to 34 degrees making pulls, it made the most HP and torque at 30 degrees total timing....from 30 to 34, there was a 22 hp and similar loss of torque, same when we went down to 26 degrees....there's no way to "feel" that or know it without a dyno....I tried different carb spacers and even air filters till we found what worked best on my engine......
An engine builder and dirt late model racer (passed away a few years ago) had a dyno in his shop, almost within earshot of my house. He'd call me from time to time on a satruday and I'd give him a hand with his race engines....we spent 2 long days on the dyno with one of his race engines, changed headers,carb spacers and used them with a combo of the 2 race carbs we had...after 2 long days, we found a total of 76 hp and about 65 foot pounds of torque over the baseline run, just by trying different carb spacers with different carbs and headers........
They are a good tool if used correctly........
David
DAVID GAGNARD
