06-03-2011, 05:21 PM
OR
If you are planning on just street driving, any Dot 3 or 4 fluid will work fine. If you plan on any track days or spirited driving you should definitely get High temp fluid. Calipers can get VERY hot on track days and you can easily lose your brakes with the standard fluid.
I've filled my system with DOT 5.1 Non silicone fluid. It is supposed to be compatible with Dot 3 and Dot 4 fluid and is rated to 570 degrees. Some of the better race fluids are rated to 700 degrees but you probably won't need this protection level unless you are racing seriously.
Bob
