Old 06-04-2011, 09:25 PM
PDUB PDUB is offline
Can't comment on that, but with what you said in this last post, I'd be suspicious of the ignition switch, since all of the issues seem to lead back to it.
Did you try wiggling the ignition and/or cycling the ignition switch when it happened before? If not, you might try to recreate the problem and see if that will have an effect on it.
