Originally Posted by Austin_Snake
Perhaps it is the starter. I was having trouble restarting the car after it was hot and turnd out the starter was going out. Probably does not help having that hot exhaust next to it. The replacement has a thermal blanket form DEI on it so hopefully this one wil llast more than 3 years.
Good luck,
Richard
Do you have your battery mounted in trunk? You may need larger battery cable..common problem.
