Help! Can't bleed hydraulic throwout in Superformance
Disconnected line from master cylinder to throwout bearing month ago. When I reattatched and went to bleed only got a dribble of fluid out
Tried vacuum bleeder...won't suck any fluid out
With bleeder cracked open no fluid comes out when you depress clutch but I do hear a gurgulling noise
Fluid level in upper reservoir not going down
Even tried to pressure bleed with 5 psi...still no fluid going out even with bleed screw completely removed
Clutch worked fine before
Any advice would be appreciated
Thanks
