  #24 (permalink)
Old 06-08-2011, 05:48 PM
BAsque1's Avatar
BAsque1 BAsque1 is offline
Hi All:
Changed the starter for a high torque wrapped it inside a heat shield, timing is fine, battery cable has the appropriate gauge for a trunk installed battery. Battery is 6mos old. Change the inline filter element and was a big improvement, also eliminated the gas preassure regulator also helped quite a lot. Just got the 1/2" (not much clearance there) phenolic spacer and will e installed this coming weekend. Will keep you guys posted. Running temp is between 180F-220F except today which were hitting the 100F mark not moving it out.
