Old 06-10-2011, 05:06 AM
strictlypersonl strictlypersonl is offline
Originally Posted by FIA-ERA View Post
...I don't really believe you have 2" to 3" of travel though. There can't be, other wise you would need longer lower arms all the way around and longer half shafts. When the car is set up right, you might have maybe 3/4" to 1" ...Regards, Matt
I'm a little obsessive about wheel travel, so with either rear suspension there's 3.5" jounce, 3.3" rebound available at normal ride height. Lower it 1" and you still have 2.5" jounce available. Since the lowered cars typically use stiffer springs for the track, 2.5" should be adequate.
I HATE cars that hit the bump stops.
