Old 06-10-2011, 05:12 AM
Modena's Avatar
Modena Modena is offline
just thinking logically some more...
definately worth pulling the rocker covers and having a look-see as Rick suggests.
each time the codes come back after a short drive
This is a new crate motor with maybe an hour of running time
this info is gold if accurate...surely its a warm-up/heat related issue then....
whats the longest you drove this engine with no issue seen?
if you've swapped the injectors from 4 to 8, what remains? Fuel-rail last-mile (almost zero chance), injector wiring/earth, ECU, valvetrain (pull rocker covers and turn engine over by hand), manifold gaskets, spark plug-seat thread (depending on compression tester used this may not show up in a compression test).
Are your headers completely custom, or are they a design known to work on other LSx? One-off's flow direction to o2 sensor would be largely unknown.....
just thinking out alound sambo!
Ben
Ben in AU
