Old 06-10-2011, 07:48 AM
wolf k's Avatar
wolf k wolf k is offline
Cobra Make, Engine: Sold ERA FIA 2139, 331 Weber IDF
Glen, the threaded collar at the base of the spring, around the shock, is where the ride height is adjusted. It is easily adjusted with a special spanner that fits the collars. Have to adjust with weight off the springs. There is 4 in. of adjustment at the front shock. However, there is a ratio between ride height and spring collar height. ERA says it is 1:1.5. So a 4 in. span in spring collar adjustment equals a 6 in. span in ride height. The rear spring collar has a smaller span, looks like about 2 in. Matt is correct in that adjusting ride height, throws wheel alignment out.
