Originally Posted by Chaplain
The carb I'm using is a Holley. When i rev the engine the carb makes a screaching noise. It sounds exactly like a belt slipping but I've checked thouroughly and it is definetly the carb. Any thoughts on what it might be?
Thanks
Chaplain
do you have the factory manifold and carb on your 429?
is there an EGR valve behind the carb? if so it may have crapped the bed and causing the screeching sound. which is a vacuum leak.....
fred
