Old 06-14-2011, 10:00 AM
Grubby's Avatar
Grubby Grubby is offline
Cobra Make, Engine: ERA 838
Default FE hydraulic lifter adjustment -correct procedure?
My FE has some lifter tick on one bank and I want to adjust the valve train. It has a mild hydrualic cam with adjustable rockers. Just over 2000 miles.
I found two procedures;
1. Bleed the lifters and then set clearance between valve and rocker tip at .100" - .200". Obviously, each tappet must be on the base circle for adjustment.
2. Determine 0 lash by rotating the push rod until slight resistance is felt and then go 1/4 - 3/4 turns more. Each tappet must be on the base circe. This is the method I am familar with.
What method is used by the top FE builders like Keith Craft, Barry, Brent Lykins and others?
Thanks.
John
