Old 06-14-2011, 09:37 PM
Paul F Paul F is offline
Senior ClubCobra Member
Correct. You need to adjust the pinion angle to exactly match the transmission. If you don't have adjustable upper or lower links, then get some. I'm assuming you have the canted 4 bar setup, like this:
Chris Alston's Chassisworks, Inc.; Chris Alston's Chassisworks, Inc. - Canted 4-Bar Rear System
edit - you can also get lower links that adjust both pinion angle and ride height.
