Originally Posted by Wbulk
You can test the canister with a vacuum pump or simply sucking on the hose fitting and then put you tongue on it to hold the vacuum. If it won’t hold in it’s bad.
Wayne
From the school of hard knocks...
Be careful, I sucked up a bug doing this. YUK
My suggestion, if using the poor boy method, is to blow first, then suck. Putting a piece of cloth (your shirt will work) between the tube and your mouth is a good idea also.
