06-22-2011, 05:36 AM
TX
Originally Posted by Donunder
The first thing to do is cover both footboxes, inside and out, with some form of proprietary insulation material. There are lots of choices available and if you can mount the outside (engine bay) insulation material in such a way that there is a small air gap between it and the footbox then so much the better.
I didn't see the need to go all out with vents for foot cooling so I had a simple piece of inch and three quarter pvc pipe made up which runs from directly behind the brake duct hole next to the grille opening. It runs up through the inner guard and mounts onto the top of the footbox directing cool air straight onto the top of my feet. Rain can't come up the steep angle at the front. Painted black so it's hardly noticeable. No adjustment. No grilles, vents, flaps or fans. Just a piece of pipe. One for the passenger too. I have to drive barefooted because of the size of my feet so I had the throttle linkage covered with insulating material as well to stop heat transfer to the throttle pedal.
We've just been through the hottest summer on record and these mods have made driving not just possible, but enjoyable. If the pipe should prove too efficient during the winter months I'll stick a black rag in the intake.  I'm a big fan of the simple approach!
Great idea also!
