Originally Posted by mln385
Looks good, any specific reason you didn't center them on the radiator? (Period correct,preference, etc)
If you mean, why not lower, then the answer is that if it were any lower than what it is then I would be pushing the clearance for the
oil cooler plumbing. Even though the plumbing isn't quiet done yet I did put the 90 degree elbows in place while I was doing the measurements. There are other issues though. One that you mentioned was originality and that was a consideration. Also, there is quite a bit of radiator up under that sloping area of the nose. This pic shows what I mean about the cooler fittings even though it's not a BDR
