Old 06-22-2011, 09:51 AM
Jerry Clayton's Avatar
Jerry Clayton Jerry Clayton is offline
You did NOT reach max speed of the dyno---they are mostly all rated up around 200 mph +-
The operator was probably watching the dyno readout for the numbers----your car guages were not a factor in this
The test range is part of the dyno set up and the readout you saw had nothing to do with the dyno but the test range the operator set up
Its your problem, not the dyno operator--unfortunate, yes, but you could of solved the ignition problem without a dyno
Again---can you tell me what kind of dyno??? mustang or dyno-jet?????
