Originally Posted by Mike Huddart
Mark, ( is this correct ? )
We are the European distributor for Accuform ( was Dynatech and Dynaformance ) and as such we have probably fitted and commissioned more of these kits than anyone else.
The injectors do not come in at 90 deg, they use the long plastic EV6 injectors which reach from just about the underside of the top plate to just above the butterfly. Not sure of the angle but it is fairly accute and when the butterflys are open inject more or less straight down the port, the angles are slightly differant from one half of the TB to the other as getting everything installed under the top plate is a bit tight and the injectors have to be angled away from each other.
In practical terms none of these compromises seem to matter much, we get great results and even pass our quite strict Cat tests with our kits
If you need any more info let me know, Mike
Yes... it is Mark.
Thank you for the info. Has the price of the TBs changed any since Accuform has taken over? I am running 48 IDAs today and was considering swapping them out. Any pictures of the injector setup you can share? I wonder why they did not go with a down flow injector from the top? Maybe they did not what people to see the injector in the velocity stack.
Thanks!
Mark
