Here is a printout of the final pull on the dyno. As per the particulars of the engine it had an original GT 40 steel race crank, carillo rods, arias pistons, HV (blue printed)
oil pump with a high capacity aviad
oil pan, stock dual point ignition, roller valve train and weber carbs, heavily modified stock iron heads and an iron block.
