Old 06-23-2011, 06:44 PM
Hissstorian Hissstorian is offline
Default new here - help on a what's it worth
Hi - this is my first post on this site. I already have a Factory 5 car and now I have a chance to get this in trade for a musclecar I have - any ideas what it is worth? sorry for crappy pics. Still trying to get the manufacturer's name from the guy...it's a serious race piece so he says - thank you very much in advance.
race fabricated. Little things like; reverse speedo,Tilton custom pedal box, Sparco quick release steering system, RJR 5 point harness,Rebco Aviation Switches, 347cid, 11.50:1 W/ Dart Alum Heads, J&E Pistons, Titanium pushrods, Raceme alternator/waterpump setup, Billet motor mounts Dyno 436hp @ RW, Dual BG Fuel system, Tremec 5 speed, Tilton bell housing w/throw out bearing, Mcleod Race Clutch, Winters 8 quart center section diff, Stange gun drilled axles, Stange alloy Pinion, Daytona carrier, Cobra Super formula 3-way adjustable mono-tube dampers, Bicknell alloy control arms & links, Bicknell alloy billet 4-piston brake calipers & cross drilled race rotors, Bicknell race engineered spindles & bearings, Bicknell race wide-5 hubs, Bicknell race aluminum wide-5 rims (3.75lbs each), full CSC race engineered tubular chassis
