  #25 (permalink)
Old 06-24-2011, 08:12 AM
lovehamr's Avatar
lovehamr lovehamr is offline
Stolen Avitar
Originally Posted by strictlypersonl View Post
Cool, but I would change the design a little bit to make it more universal.
Instead of directly welding the half-clamp to bottom of the Vise-Grip, I would weld in a U-shaped cradle that could support a floating half-clamp. That way, you can use the tool on different diameter tubing.
Since the center of pressure for the tool is in such a small location, most of the anvil (my muffler clamp) could be cut away with almost no effect on the end product or its ease of use. I used the muffler clamp saddle because it's what I had and was roughly the right width. With the set up the way it is now it could be used on anything up to 3" and on the low end, anything that the "hammer" portion will fit into. By removing most of the anvil the upper useful size would be almost unlimited and rounding the lower jaw portion would make it usable on smaller tubes as well. So post pics when you get yours done.
