Old 06-27-2011, 10:10 AM
SSSammy's Avatar
SSSammy SSSammy is offline
Originally Posted by Kramer View Post
Thanks Sammy. FYI...regarding your starter from Tilton.
1) Does it turn the motor over without effort (as opposed to a stock OEM starter)? I have had both a powermaster and now a OEM starter.
2) What BH are you running in your car?
Kramer
http://www.tiltonracing.com/incs/ima...?picture=s0052
The Tilton 54-20013 has the Ford 3 bolt flange. It is 3 HP and will spin my 482 easily. Rick Lake says he uses his to drive his ERA up into the trailer when it won't start But they are expensive - $459 at Summit. But the PowerMaster ought to get er done if it is equivalent HP. I wouldn't use the OEM for a high compression BB motor on a hot track day. For street use it might be ok. I use the Lakewood 15210, with the bottom trimmed per ERA manual.
Sam
