Piper......
If you are using the CR stock rear suspension with the adjustable rear spring threaded rods.... Just about anything you do will improve the ride. Coil-overs-ANY brand is a huge improvement. If you car is pretty much stock a 200 lb spring rate, Penske,Eilback, QA-1's, Pro, are all huge improvements.
DV
