Old 06-28-2011, 09:10 AM
winnipaw winnipaw is offline
Cobra Make, Engine: Backdraft 427 FE 4spd
Was your original column installed new? 11K should not be a wear problem. Check for side to side movement at the firewall bearing. If equipped with a rag joint, that could be source of excess vertical play.
