Starting to notice that the water temp is starting to run a little on the high side 90c - 95c seen 100c on a hard pull. This is higher than where it has been usually 80c - 85c. Pulling the Tstat for replacement first then on to the next idea
Problem is that with the higher temps the carb is starting to perk and floods when shut down, hard to start black smoke.
Coolant level is the same, fan running ok, no noise from the Wpump, no overflow from the Ptank, nothing from the pipes.
Has anyone bumped into this?
Thanks
Rich
