I upgraded my fan to the Lincoln 2 speed fan and shroud using a custom harness from The Holister Road company. Ran my coupe in Phoenix last summer when it was 114 degrees out with the A/C running and never got above 205 even in traffic.
If it's only hot in traffic you need better fan/shroud setup to improve airflow through the radiator. If it's hot all the time you need a better radiator or there's another issue causing the problem.
