Old 06-30-2011, 04:17 AM
Default Might need 2 gaskets glue together
Jeff Frigo Jeff 2 gaskets glue together and not over tighten your hold down plta for the distributor. Unless you have a good clean area,RTV will not seal to the manifold and housing. You need gray or silver RTV. 24 hour cure time. For oil to be coming out of here, you may have a problem with the motor, too much back pressure?? Miss a shift or over rev the thing?? This a funny place to leak oil. Check the corner of the valve covers too and bolt hole under the distributor. Have seen the intake gasket walk up the manifold and cause this leak. looks like distributor but is other place. They sell a dye check kit for about $45.00. You get dye, glasses and light. Makes finding leaks real easy. Rick L.
