Originally Posted by psychoSEAL
Battery engine off 12.5
At 1200 - 1500 rpm 14.3
Engine warmed up with fan on 13.9
Ran another ground wire to a different location on block. Light did not come on until running for about 1 mile. Light came on and then off after a few seconds. Drove approx 3 miles with no alternator light on. Checked voltage at altternator when running. Same reading 13.9 with fan on. ???????????
13.9V at what RPM? Which fan? (or better yet, how many Amps does it draw?) 13.9V at above 1500 RPM with the fan on is marginal, so I would suspect a bad diode in the alternator. Less likely: bad battery.
