Originally Posted by gsharapa
Stupid question but I assume when you are putting it on 36 total you are running the rpm up passed 2500 or where ever it maxes out prior to putting it on 36 total? With campy gas these days I use to run my 351 around 34 total. If you still are having problems after all above recommended you might have the distributor check or try a different one but those old Ford balancers with the rubber ring especially if the rubber is cracked slipped all the time,,,
yes, it max out at around 3500.... can try 34 and see what differs.. ok, we in Europe have still 98 octane....but first i will have to check TDC on piston 1 , even if i can't reach it well...
or.. is there another piston number firing at the same point at 1 crankshaft rotation later what would be the same for the timing light ??? more aft so i could reach it better to find TDC ?
looked it up for a 351C... should be the 5the cilinder firing, beeing number 6 which is second from front left side ... this one i can reach alot better ! I'm i right ?
Now what can we put trough the sparkplug hole to see it raising/stop/going down ??? a "straw" ( spelling ? ) as children use for drinking out of bottles ?
