  #24 (permalink)
Old 07-05-2011, 02:27 AM
PeterAllen's Avatar
PeterAllen PeterAllen is offline
Cobra Make, Engine: Puckett 250 GTO - LS1
Mike - I'm not quite with you. Are you suggestion a solid mount?
I have rubber mounts between the hoop and the tunnel brackets - call me a wuss but it's for touring not racing. The big issue is the two front mounting bolts on the diff, which you have used, are set some way back and are much higher than the original diff bracket bolts on the tunnel. The rest of the shell is so light and weak I need to use original mounting points. There's a real cantilever problem with any design.
