The t/o bearing will not fall out. It is held by the fork. ALso, the clutch will maintain alignment as it is clamped by the pressure plate. Use the order above and a new T5 will bolt right in. If you are upgrading to a TKO you will need a new bellhousing and with a TKO600, a new clutch disk.
RCR GT40 SOLD to Fast 5
Kirkham #690 289 FIA
