Old 07-05-2011, 11:12 AM
RestoCreations's Avatar
RestoCreations RestoCreations is offline
Cobra Make, Engine: Kirkham 289 FIA, 363 Stroker
Default Fuel Sending Unit wiring Help
My fuel sending unit is a newer type that measures electrical resistance, it is not the float type. On the sending unit there are connectors for a POS, NEG, and Sending unit wires. My question is, where does the POS cable connect to.
I have the gauge wired correcdtly with the sending unit wire, a 12 volt supply, and a ground. It reads below zero with just these wires connected, even though there is 4 gallons of gas in the tank. If i connect the POS wire from the fuel sending unit to a 12 volt source, the gauge pegs out past full.
Any help would be most appreciated.
Thanks
