Old 07-06-2011, 04:07 AM
Default What trans is in the car and input shaft??
Wbulk What bell housing and trans are you running?? This looks like thrust bearing that has been shaved. If you are running a GM input shaft in some ford motors, with a lakewood bell housing, The input is too long by .380" This need to be removed to unload the crank shaft. We don't know your new buildup but they have changed the back ends of crankshafts and not cut them as deep as needed. More info on the bottom end will help. Rick L.
