Hi-Tech built their own wiring harnesses in the early days too...your 023 should not be much different the the earliest version wiring on cars up to 1040. The earliest car are not well documented but the parts did not change much from yours...
You pretty much have 2 headlights, 2 running lights, 2 turn signals, 2 fans, brake light switch, low level brake fluid level, the charging system (voltage regulator / alternator), one 4 fuse panel, and the ignition system if you still use the stock dura-spark system.
SPFWiringDiagrams@Comcast.net
