Old 07-06-2011, 11:14 PM
ACO05's Avatar
ACO05 ACO05 is offline
Cobra Make, Engine: DRB, Edelbrock Endurashine 347 Stroker, Boss Block, 5 speed manual
Send a message via Skype™ to ACO05
Default Windsor 302 Pulley Kit
Hi All, Need some advice on a pulley kit for a DRB replica. Just fitted a new engine configuration 302 Windsor block with 3 bolt balancer and a mechanical water pump, going to use existing alternator. Rocket industries supplied the 347 ci Elderbrock Ford Performance engine complete with water pump, alternator bracket and March Performance Serpantine pulley kit ( no a.c or psteer ) this pulley kit touches the steering arm. Original engine had an electric water pump and open style timing belt so is completely different to the new configuration.
Can you please let me know if you have this configuration and what type of pulley kit and alternator bracket you are using.
