Originally Posted by Don
tin-man:
Additional Info from Terry:
" It would be no issue in matching the screw pattern if different. Superformance is the only manufacturer or whoever they are supplied from that has been different.
3/4” center to center is what is standard and 13/16” center to center is Superformance. If yours is different I can accommodate. "
Ask Terry:
" Only one issue, do these mirrors move when the wind wing moves, seems like , so how to make a permanent fix? Is such a fix available? "
Contact:
Terry L Riebel
www.thedreamcarcompany.com
502 802-1159
Pictures:
tin-man: If you wish to PM me your e-mail address, will forward the pictures from Terry, was not able to post via CC......might be the size of the file or ?
The intent of the design is to not impede windwing movement. When installed correctly the mirror and wind wing will swing away when in use with side curtains. When installed correctly the mirror and wing will be very stable, and hold it's setting. The design does not require additional drilling of the windshield post if you do not desire to do so.
This kit works
with the installation styles of the wing.
This kit does not impact concerns of the purist as it can easily be removed for shows if needed or for those who are you selling your car. Remove them and place them on your new car.
