  #35 (permalink)
Old 07-07-2011, 09:51 AM
67FEfastback's Avatar
67FEfastback 67FEfastback is offline
Originally Posted by 482supersnake View Post
Dougs main problem is pan clearance or lack of clearance to the ground. I wounder if you could shorten your pan at all and modify the pic up tube? Scott
I think, that is the route, that I am looking at now. I am going to try and round up a stock front sump pan, and modify that. I think, that if I keep to the stock pan depth, I should be able to get the ground clearance that I need.
I don't know if I have the room to install an oil tank for a dry sump system.
This is the (now replaced) Cobra Tee pan
It was since replaced with a Moroso pan which gives me 1" more clearance. Obviously the car is stopped, but gives an indication of how it might look under heavy suspension travel.
http://youtu.be/1x63nB64zyM
Thunder
