Good point. I'd actually forgotten it was the Iron Man car, so of course you want to keep it as close as possible.
We have a franchise company here in the UK called Chipsaway, who can match and paint pretty much any paint defect. They specialise in stone chips and scratches and operate from fully equipped vans, so they can go to the customer. I would have though there were similar companies in the US.
Putting an edging trim around the hole just won't look right, IMO.
Looking at your picture with the tape measure, that dimension is about right for the top of the hole. I've just been out to the garage to measure mine and it tapers from around 6" at the top to around 8" at the bottom. If you hole has parallel vertical sides at around 6", you can still get the correct taper.
Paul
