If I understand your post right your saying that even though the 390 piston is used the piston still has to make it to the top of the bore with the shorter stroke and longer rod....
If that's right well it's kinda wrong, the pickup engines all had a piston well below the deck, hence the 390 piston being low is what they used for the low compression. Also as far as I know the main difference between the original 360 pistons and the 390 pistons used in 360's is. The 3.5" stroke 352/360 piston still used a full skirt that didn't need cut back to clear the crank counterweights at the bottom of the stroke, but the 390 piston did need cut back. (my assumption) Hence when they wanted to save money they used one kind of piston (the cut back 390 piston) for the 390's (high compression) and 360's
Originally posted by Toadmanor
Thanks FE, Somehow with the shorter stroke, the pistons have to get to the top of the same block though, Either the pin sits higher or the rod is longer--else the piston would be down in the hole a bit!
