  #22 (permalink)
Old 07-08-2011, 04:09 PM
Michael C Henry Michael C Henry is offline
Cobra Make, Engine: Everett Morrision FE 427 so 2-4s
Anyone know anybody that manufactures inserts for the top channel of the windsheild frame? I'm thinking about two inserts in the top channel about 4" on either side of the opening with one or two threaded screw holes going down towards the windsheild. They would for the most part, be left there when not in use. Not a couple of machine screw nuts ground to fit but a couple of machined inserts, each an inch or so long to spread out any force. After thinking hard and ruleing out different ideas, What I'm thinking is two inserts installed in the top windsheild frame channel. My LongAcare 14" mirror has two verticle sheet metal brackets with a horizontle 1/4" bolt , back about 9 1/2"apart. I'd mount mirror bracket to intermediate"L" brackets to insert .LongAcaer 14" mirror would be on top of windsheild frame with mirror ends benind my sumvisors. My sunvisors are usually upwright and act like windseild extensions anyway, because my windsheild is leaned back so far it's height is reduced.
Back to windsheild frame top channel inserts?
Mike H
