Old 07-10-2011, 06:55 PM
Ant Ant is offline
Default Dry sump pan
Originally Posted by vector1 View Post
these people made mine, tell him exactly what you want and he should make it, specify where you want the dash fittings and the pickups and depth. i've heard good and bad but my pan and valve covers turned out workable, had to use some good rtv on the front and rear portions of the oil pan. i had an aviad pan that wouldn't fit--the dart block requires a pan that will clear the rear 4 bolt main, and sent it back, i wasn't going to hammer it. a pan that fits the dart block will fit a production block btw, but not vice versa.
Welcome to Billet Fabrication
Will give them a look, its a bit annoying with the amount of Dart and SVO blocks in use for Pan makers to have oil pan clearance issues!
A J. Newton
The 1960's rocked!
