Old 07-11-2011, 06:23 AM
priobe's Avatar
priobe priobe is offline
Cobra Make, Engine: E-M Cobra Ford FE 427 w/ Webers 48 IDA
Hello all,
I live in Miami FL where temp reach 95 F this particular day. I use to run into the very same problem and it use to be very bad. I would have to hold the throttle plates open to start the car after a drive and letting it cool for about an hour.
What I did was adjust the floats using the weber adjustment too that I made to 5.5 mmfloat height and 24.2 mm tang height.
I have driven the car and each time car starts right up. I would even keep the fuel pump going to lower fuel level, and I have no need to do this anymore.
I would check your floats adjust them to default setting and if the car runs bad use a correct emulsion tube to tune your driving experience.
So far its working for me.
I am also using the spacers
