A big 'Duh' from me. I know heads are reversible for one casting.
So block first then through the deck to the heads. Wolf you state the water flow is regulated by the size holes in 'the intake gasket'. Do you mean the head gasket instead??
The intake gaskets at the head exit are much larger than the casting hole. Here's mine before clean-up:
Thanks to you both for text-book answers.
