Old 07-15-2011, 09:01 AM
legenmetals's Avatar
legenmetals legenmetals is offline
Cobra Make, Engine: contemporary(2) one with 427 sohc and one with 427 center oiler
Make sure none of the screws around the perimeter of the windshield come into contact with the glass or it will crack again. The windshield frame cannot be preloaded or stressed when tightning the framework mounting screws or bolts. Shim these attachment points so the framework doesn't get sucked in,if you don't do this the frame will stress the glass and it may break from bumps on the road or heat exspansion.
