John---we do a lot of tune work on those engines including the tune work on the NICKEY Camaros---did you by chance use an o2 sensor extension wire kit???We have seen some work where wires are extended that the extender person had wired the terminal plug in a mirror image (backwards)
Could you PM me with the name of your wiring harness and details of it?
Thanks
PS---we also have seen issues of differances between corvette and camaro wiring and also with when using the ford 2 bar map sensor with gm computors(of course it takes a custom map)
