trying to find a show type pullies as stock type in size.Also will cet an aluminum fan shroud and have it polished.Will get waterwetter .but the first thing is to pull the them. and see if it makes a big diffrence.If it does than will get a better therm. with a wider opening such as a cut down dodge therm..No,I won't run without a therm. but only to see if this is the culprit since the water flow is very slow.Either a restriction from the therm. or the pullies. Anyone know where I can pick up polished sock size pullies?Sounds like a plan?Start off most obvious fist then kill them off one at a time right?
