Originally Posted by DaveW
Paul,
Have you got a pic of the inside of one of your Vintage Wheels, also, if you have, the distance from the mounting face and the "spokes" (i need some caliper space), and the overall spoke thickness, i'e front to back.
Spoke with Vintage Wheels and Team 3, i need to loose 32mm a side to fit the front wheels and maintain the current wheel to guard distance (3/4" + 1/2" for knock off flange).
VZ hubs, taking out 32mm might be a trick, there's only 16mm between mounting and wheel flange.
Dave with the Jag hubs its quite easy to loose 30 mm from the hub,moving the wheels inboard.
Im not too sure about the Commodore hubs.
The Vintage wheels centers are very think about 62 mm
And the distance from the hub mounting face to the webbing of the wheel is 20 mm.
I hope this is of help
Thanks Paul
