  #21 (permalink)
Old 07-19-2011, 03:47 AM
undy's Avatar
undy undy is offline
Originally Posted by Jimeg View Post
I'm having problems adjusting the low beams of my HID headlights. My left beam is too far to the left and a bit high. It also has a much narrower beam then the left side. (Possibly it's a faulty light). The right side has a wider or normal type beam but it's too low and.... I'm out of adjustment for both headlights. Strange situation as the high beams are perfect. I'm at a loss here , any thoughts? At this juncture I just might use the high beams all the time. The strange thing is a local friend with a BDR is having the same problem and results.
Funny you should mention this... but ... I've got the EXACT same problem with my retrofit HID bulb kit. No matter how you adjust it there's shards of light that shoot off up and to the left. I contacted the supplier of the kit and was told it's an adjustment problem. It's not an adjustment problem! I band-aided it as you did by adjusting the bulb to point downward in front of the car. It's to the point I don't like driving it at night for fear of offending on-coming drivers. I'm considering uninstalling the kit and returning to my regular headlights. I was warned by others and should of listened.
Here's the link ...
COBRA H.I.D. Conversion
Too many toys?? never!
